HDC doesn't work but no indications
Old Oct 2, 2010 | 12:14 PM
GoldDiscoII's Avatar
Default HDC doesn't work but no indications
Tried the HDC today going down a buddies steep incline. It's worked in the past but today all I get is the dinging and the green blinking light. No fault indications that anythings wrong, except it just isn't working. Read the manual multiple times to verify I'm doing everything right and I am. Yes, it's in low range. Any ideas? Thanks.
01 Discovery 90,000 miles
Old Oct 2, 2010 | 05:12 PM
Willie00d2's Avatar
Are the 3 amigos on? If they are it will not work.
Willie
Old Oct 2, 2010 | 05:27 PM
Willie
No, I have nothing on the instrument panel except the blinking HDC green and the dinging. It's almost like it's not sensing low range being on. But low range is engaged.
Old Oct 2, 2010 | 06:35 PM
Was your t/case in low range and your tranny in 1st. or 2nd.?
Old Oct 3, 2010 | 09:25 AM
05gixxer's Avatar
I have the same issue (Gold disco) I am thinking along the same path as you in that the truck is not sensing low range is engaged, as everything else on the truck works perfect if you figure it out please post solution. I do a lot of wheeling with my truck and would love to use HDC.
Old Oct 3, 2010 | 07:11 PM
mwindth's Avatar
Talking Start a new thread...
Originally Posted by dansol2518
Self Leveling Suspension on my Disco 2 broke. Toke it to Wheel Works, spent $650.00 to fix it but still SLS leaks air. Can anybody help me figure it out on how to fix it?
Start a new thread...and use the search function (hint:type in "SLS air leak")...I'm going to go out on a limb, take a wild guess and assume that a "Wheel Works" knows nothing about Land Rovers.
Why not convert to springs and forget the hassle?
Old Oct 4, 2010 | 08:21 AM
Another new-be that can't read or think.
Old Oct 4, 2010 | 08:23 AM
Did you have the CDL light on, on your dash and if you gave it power, were you in low range? If so then the ECU knew you were in low lock, not low.
Old Oct 6, 2010 | 08:18 PM
discoklein's Avatar
does it matter whether you have the cdl locked or not in low range...? both of my disco's HDC's work fine in low
Old Oct 7, 2010 | 10:23 AM
May be time to read your owners manual to learn where you are coming up short on this.
