Head bolt
Old Feb 21, 2011 | 10:02 AM
Eak69's Avatar
Default Head bolt
Last time I replaced the head gasket, the engine was sitting on a stand -which made ALL the head bolts easy to get off, on, and torqued properly.
As I am trying to pull the heads again - I am having a @#&% of a time trying to get the very last one (nearest to the firewall - on the bottom) off. If I am having a hard time getting it off - I can imagine trying to getting this sucker torqued correctly when I try to put it back together.
And it is not the fact that it is 'stuck' - I just can't get a socket back there.
With that said - I know we have had 'countless' gasket replacement jobs on this board - what do you find (or what do you use - impact not allowed since 'I ain't got one') to fit a socket/wrench combo to get it off - and then put back on?
Thanks in advanced for the help!!
Old Feb 21, 2011 | 12:30 PM
Bundu's Avatar
Banned
You need a 1/2" shallow 6pt impact socket with a 1/2" impact wobble extension on a 1/2" breaker bar with a 4' cheater bar. That combination will make it easy. Get the impact socket and extension because they are built stronger and will not break. The 6 pt socket grips the head bolts better and prevents slipping or rounding the bolt. You can get these are tractor supply for relatively cheap.
Old Feb 21, 2011 | 01:54 PM
Eak69's Avatar
Ran out to the store and got it - THANKS!!
You saved me a few hours.
I will have to get the 'cheater bar' next - I had one but I think I left it in a J/Y somewhere in Chicago.
I got the bolt off using sheer determination (and a lot of swearing) but I know better to try to reassemble it without the cheater bar....
Thanks again.
Old Feb 21, 2011 | 01:59 PM
DiscoKline's Avatar
When you put them back in I don't think you can hardly do it with one person. I had a helper hold the socket in place and watched the angle gage, while I pulled the breaker. This made things much easier. If you need and angle gage, I found mine at Autozone for $9 I belive, and it makes it much more accurate than just marking the socket and trying to get 90 degrees...
Old Feb 21, 2011 | 03:36 PM
coors's Avatar
Very good recommendation, I picked one up awhile ago. Accuracy counts with these head bolts.
Old Feb 21, 2011 | 04:54 PM
Eak69's Avatar
Yeah - I have one of those - and I had to make sure the engine and stand were up against the garage wall when I did it so it wouldn't slide around.
Lie I mentioned - it was cake when I had it out of the car - so I am assuming the total opposite when the block is still in the car!!!!!
focusontheworld
Oct 21, 2012 01:00 AM
aublec22
Sep 16, 2011 07:27 AM
EVN137
Jan 7, 2009 04:37 PM
dcnellie
Oct 31, 2007 09:14 PM
jcostello
Nov 2, 2006 10:28 PM
