Head Bolt Problems
Old Aug 21, 2014 | 04:49 PM
tdmadlem's Avatar
Default Head Bolt Problems
having problem removing 3 headbolts on left side head -- center bolt & rear 2 bolts at firewall side -- using 16mm 6 point 1/2" drive socket -- socket has slipped on bolt head & head is now slightly deformed; socket will not grip securely on bolt head to allow removal; tightening 18" breaker bar allows socket to slip off bolt head before turning; all other 17 headbolts came loose without any problems;
I would think someone else may have had this problem before -- can anyone offer suggestions on how I can get these 3 remaining headbolts to loosen? I retightened bolts adjacent to the stuck bolts but this action didn't seem to help;
any ideas for some different tool or method would be very much appreciated; I am pulling heads mainly to replace headgasket on right side that was blown to outside edge;
Old Aug 21, 2014 | 10:20 PM
acamato's Avatar
The bolt heads are 5/8". You can try a 5/8" 6 pt socket, it will fit a little tighter than a 16mm socket. 5/8=0.625 and 16mm= .630"
When I pulled my heads I had an issue with the rear bolt next to the exhaust manifold on the drivers side head due to access.
Old Aug 21, 2014 | 10:44 PM
abran's Avatar
If they bolt heads get bad, try these:
http://m.harborfreight.com/38-in-drive-sae-bolt-extractor-sockets-9-pc-67897.html
Old Aug 22, 2014 | 07:08 AM
drowssap's Avatar
you should un-torque the head in the opposite direction that you would torque the head.
you now have all the pressure locked down by just those last two bolts, a common mistake.
i would reinsert the other head bolts to release the tension, then you should be able to remove the rear head bolts using a 6-point 5/8 shallow impact socket and a short extension.
Old Aug 22, 2014 | 08:09 AM
Jared9220's Avatar
use a 5/8 socket not a 16mm. If you have a helper around have them hold the socket straight down on the bolt while you turn the breaker bar.
Old Aug 22, 2014 | 09:53 AM
dr. mordo's Avatar
This is a good idea, but just to be clear don't try to 'torque' the bolts back to spec. Just put some tension on them to equalize the pressure across the head.
Old Aug 22, 2014 | 09:57 AM
drowssap's Avatar
that is correct; you just want to release a little tension
Old Aug 22, 2014 | 02:54 PM
jfall's Avatar
Use the 5/8" 6 point BLACK impact socket.
Only impact will hold up.
On top of that put an impact svivel joint.
Then a short stub extension.
Then a breaker bar.
Put a pipe over the breaker bar for leverage.
That will get it off.
From March 2012 in Boulder CO
https://www.flickr.com/photos/76579732@N07/
There are some examples in the pictures of what you are attempting to do.
Old Aug 22, 2014 | 06:13 PM
tdmadlem's Avatar
many thanks for all the help & advice! I was able to remove the last 3 bolts today;
using the 5/8" impact socket plus having a helper to steady the socket while using breaker bar did the trick! I thought the Rovers were all metric fasteners -- but I was wrong; not much size difference between 5/8" & 16mm -- but enough to make a big difference! busy this weekend, but plan to start reinstalling the new gaskets & cyl heads next week! will keep posted when my 2003 D2 is up & running again!
Thanks again - very much appreciate all the help!
focusontheworld
Oct 21, 2012 01:00 AM
aublec22
Sep 16, 2011 07:27 AM
EVN137
Jan 7, 2009 04:37 PM
dcnellie
Oct 31, 2007 09:14 PM
jcostello
Nov 2, 2006 10:28 PM
