Head Gasket 2000 Disco II
Drewak1, if you are going to phiscally inspect the oil pump you need to drop the oil pan, front frame support, pull the water pump and timing case cover. You might want to button up the topend first, otherwise you will end up with just a short block sitting there. JMHO And oil pump problem are USUALLY in the later models.
Thanks Guys,
There was evidence of the leak but nothing deep. I surfaced the head in my mill only removing .020" overall and it is flat now.
My only concern is with the compression having not surfaced the other head. BUT I ran some calcs and the compression diff between is actually minimal.
Thanks for the tip on the oil pump I will check it out !
Do you guys use Copper Spray on the head gasket ? This is what I use on Diesel engins when I rebuild.
http://www.permatex.com/products/aut...ve_Sealant.htm
Thanks !
Thanks !
willtillery@roverguy.com
there is another guy drill bit (marty) has an ebay store "iamdrillbit" is the name.
they part out LR's I'm sure one could help
here is a complete upper and lower with a throttle body that Marty has for sale for under $80.00 contact him.
OEM LAND ROVER DISCOVERY 2 PLENUM CHAMBER INTAKE RANGE | eBay
