Head Gasket... Complete!
Old Jan 4, 2011 | 08:23 AM
willrok13's Avatar
Kcab,
I did find the source of my leak, it was the valley pan. I posted on the forum and decided to proceed with replacing the head gasket as a precaution. It may not have been necessary -- but I would have been more irritated if after reassembly I still had a coolant leak than I am with the tick. I'm going to take a close look at the SAI system today, after reading a few posts, I think it may be the culprit.
Old Jan 4, 2011 | 11:27 AM
willrok13's Avatar
Good news! The secondary air fitting wasn't quite tight -- no more tick! Thanks for the help, I never would have thought about the SAI fitting.
Old Jan 4, 2011 | 11:49 AM
JEFIII's Avatar
Will,
Good to hear you found the culprit. Are you talking about the fitting/adapter on the head or the big nut from the pipe to the adapter?
Thanks,
JF
Old Jan 4, 2011 | 08:35 PM
willrok13's Avatar
Jef,
I am talking about the big (36mm?) nut that tightens to the adapter in the head. I was a little worried to tighten it too much because of other posts I read where the copper pipes have cracked. It was hell trying to loosen those nuts. I drove the truck from Auburn to Birmingham, AL today and it didn't miss a beat.
Old Jan 5, 2011 | 02:10 PM
kcabpilot's Avatar
Having just figured that out myself it is a 27mm for the B-nut and 18mm for the nipple that screws into the head.
Old Jan 5, 2011 | 02:58 PM
JEFIII's Avatar
Thanks for the info. I'll tighten mine up later this evening. The copper pipes make me nervous as well.
JF
SkymonkeyONE
May 8, 2013 12:29 PM
bcolins
Mar 28, 2011 04:15 AM
GreggWSmith
Mar 4, 2010 10:41 AM
cobbcj7
Dec 14, 2009 02:15 PM
cobbcj7
Dec 9, 2009 08:22 PM
