Head Gasket and Hood Removal
Old Sep 4, 2012 | 11:24 PM
DiscoRover007's Avatar
When I put mine back on I just pulled the hood towards the front bumper as far as it would go and tightened. That gave it enough clearance to not ding anything. It looks right to me now, haven't noticed alignment problems.
Old Sep 5, 2012 | 06:48 AM
drowssap's Avatar
remove the hood, but before you do it drill a 3/16 hole threw the hindge into the bottom of the hood.
Then when it is time to reinstall it you can just stick an ice pick in the hole and the hood will automatically line back up
Old Sep 5, 2012 | 02:04 PM
coors's Avatar
Don't do this. If you dont feel confident enough to remove and re-install the hood definitely do not drill through your hinge.
As Disco Mike stated, outline the hinge w/ a marker before removal. Its very easy to re-align. Just don't tighten the four bolts and go slamming the hood closed. You may f-up your fenders. Ease it closed and check the lines on each respective fender to make sure they match. Done.
The hinge has structural properties why would you drill into it and remove material from it?
Old Sep 5, 2012 | 04:19 PM
drowssap's Avatar
I didnt say drill a 13/16 hole, I said a 3/16 hole. Done every day in restorations shops across the country.
Old Sep 5, 2012 | 08:49 PM
allroverthatwhip's Avatar
i thought we there was a headgasket getting done here!! whats with all the hood talk!!! anyways i am taking my hood off. next step?
Old Sep 5, 2012 | 09:15 PM
lr2001silver's Avatar
Banned
The discussion was to remove the bonnet or not to remove the bonnet. REMOVE IT...
Old Sep 5, 2012 | 10:55 PM
i'm loving the land rover comunitty. its very humorous. now lets talk about some headgaskets causr im anxious how these badboys come apart without cutting my fingers. haha i acctually like my truck without a hood on it looks so mean.
Old Sep 6, 2012 | 02:16 AM
montana968's Avatar
Default um what?
i did head gaskets. take the hood off. when i was done i put it back on while drunk. the head gaskets i was sober for.
Old Sep 6, 2012 | 01:11 PM
focusontheworld's Avatar
Took the advice of most here and removed the hood. Used a marker to outline the location of the hinges. It's sitting in the back of the shop hopefully where it will stay out of trouble while we do the head gaskets. It is a 2 man job to remove the hood. Thanks. Tom.
Old Sep 6, 2012 | 11:41 PM
griff907's Avatar
5th Gear
I'm actually in the process of replacing my head gaskets, the hardest part was getting the fan off of the water pump for me, which i was not able to do. I just took the pump and fan off as one unit after 2 hours of yanking on breaker bars. I didn't find it too difficult to get down to the heads though.
