Head gasket job Questions
Old May 11, 2018 | 08:48 AM
  #131
Saturnine's Avatar
Yeah, these "kits" come with a lot of extra crap. Next time i'm just gonna order the HGs and a few o-rings.
Old May 11, 2018 | 08:56 AM
  #132
abran's Avatar
Oops!
bottom right might be fuel injector seals. Sorry, go dig them out of the trash...
Old May 11, 2018 | 11:22 AM
  #133
CollieRover's Avatar
Originally Posted by abran
Trash, except for top right seals. Those are valve stem seals for the heads when they are rebuilt.
Thanks ABran, I was wondering what the heck all this was.
Old May 11, 2018 | 12:31 PM
  #134
Well, I think I have the wrong intake manifold clamps. I will have some genuine from the dealership tomorrow. I just could not see any way they installed properly.
Old May 11, 2018 | 02:07 PM
  #135
Sixpack577's Avatar
Originally Posted by CollieRover
Reading through the RAVE and my next steps. It says to lubricate the new "Coolant Rail O-Ring" but does not say what to lubricate it with.
Oil? Coolant? Water? Any ideas?
Did some searching, found it should be a silicone lubricant. I do have silicone grease, so I will have to check and see if that will work.
I have lithium grease, so am going to have to source some lube.
After research I am going to get some Plumber's Grease at Home Depot. They have high temp.
vaseline
Old May 11, 2018 | 03:04 PM
  #136
Originally Posted by Sixpack577
vaseline
I have vasoline!
  #137
Oops!
I got new injectors so I should not need those right?
Old May 11, 2018 | 03:33 PM
  #138
abran's Avatar
you need them.
2 per injector.
Old May 11, 2018 | 03:46 PM
  #139
Jeff Blake's Avatar
reman injectors should come with new pre-greased o-rings, so no
Old May 11, 2018 | 03:50 PM
  #140
Sixpack577's Avatar
Vaseoline on injector o-rings, and any and all o-rings.
It's a petroleum base, harms nothing, and is perfect for lubing o-rings, preventing them from being cut or damaged.
