Head gasket job Questions
Old Apr 5, 2018 | 06:42 PM
  #51
Jeff Blake's Avatar
https://www.harborfreight.com/engine...-pc-69020.html
Old Apr 9, 2018 | 12:20 PM
  #52
CollieRover's Avatar
Ok guys, let me know if this is folly.
I need to have the rovers locks working so I can get to my tools, so I need the battery hooked up. I can quick disconnect it when I work on it, but when done re connect and lock.
I think what I need to do is pull the fuel pump relay, and also wrap the positive cable to the Alternator in electrical tape. Position it out of the way and not near ground.
Should that do it?
Old Apr 10, 2018 | 08:51 AM
  #53
1. I would love to know when you guys use anti-seize and what product. I've got the grey, copper, and grease to use.
2. I would also want to know when you guys use threadlocker.
I plan on following Rave so that may answer my questions for me, but your input would be awesome.
Old Apr 10, 2018 | 09:11 AM
  #54
Saturnine's Avatar
I use the grey/silver stuff for anti-seize. Copper is more for brake pads iirc.
i don’t use threadlocker stuff to often but when I do it’s usuallt the blue not the red.
I don’t think there is much of anything that needs thread locker for a HG job
Old Apr 10, 2018 | 09:31 AM
  #55
Originally Posted by saturnine
i use the grey/silver stuff for anti-seize. Copper is more for brake pads iirc.
I don’t use threadlocker stuff to often but when i do it’s usuallt the blue not the red.
I don’t think there is much of anything that needs thread locker for a hg job
thanks!
Old Apr 16, 2018 | 09:17 PM
  #56
Originally Posted by Sixpack577
My phone is being tempermental, and won't add a link.
On ebay, search for, land rover discovery bosch fuel injectors.
You'll get several choices, with good returns and extended warranties.
I saw $65, $80, and $90 a set, depending on seller.
Hey Sixpack, did you need any new o rings washers or clips when you changed your injectors?
Old Apr 17, 2018 | 06:30 AM
  #57
Sixpack577's Avatar
No sir,
Remanufactured injectors came with new o-rings.
Metal clips are reusable, and new injectors are a direct replacement.
You don't need anything else.
Old Apr 17, 2018 | 09:24 AM
  #58
No sir,
thank you. I have way too much time to think about this job with the weather being the way it is.
Old Apr 17, 2018 | 10:29 AM
  #59
Sixpack577's Avatar
Lol,
It's finally trying to warm up here.
I've spent the winter collecting parts, and fixing small things.
Now I have to get motivated and put it all back together.
Old Apr 17, 2018 | 07:29 PM
  #60
Lol,
It sucks. I got very little done today. Going to do a little bit each day.
