Head Gasket Leak?
Old Apr 3, 2013 | 05:03 PM
seedsntrees's Avatar
Default Head Gasket Leak?
2004 Discovery, 94K miles.
Vehicle has been in storage for the past three months. Started it last month to warm up. No smoke or order of burning antifreeze.
Today, noticed a puddle of antifreeze on the passengers side on the floor.
Took a quick look and it appears to be from the head gasket about in the middle of the engine. Not sure of a water jacket being there?
I did not have time to look any further, but I don't think there are any hoses that could be leaking in that area.
Looks like a head gasket to me.
Any ideas what to check for orther than a gasket?
Thanks,
Old Apr 3, 2013 | 05:39 PM
Bkreutz's Avatar
Thanks,
Pressure check the cooling system, there are a number of hoses going to the coolant reservoir on the passenger side, and there is an overflow pipe that comes out of the reservoir and points towards the ground.
Old Apr 3, 2013 | 06:15 PM
blackhills's Avatar
did u top off the coolent ? the overflow piddels out there
Old Apr 3, 2013 | 06:35 PM
Dave03S's Avatar
Last time I looked the coolant overflow pipe doesn't drain to the passenger compartment floor. Sounds more like a heater core issue.
Are you sure it was coolant and not just rancid water from a plugged AC drain nipple? might be a good idea to check your nipples.
Old Apr 3, 2013 | 07:08 PM
jhill15's Avatar
I had this same problem in an 87 trooper that I owned years ago, way different from our rovers but antifreeze in the floor of cabin is more than likely a heater core. In the trooper it was like an explosion of antifreeze went off and started pouring in from behind the dash while the engine was running.
Old Apr 3, 2013 | 07:20 PM
Thanks for the ideas, I will take a second look....but clearly the area between the head and block was wet with antifreeze.
Perhaps it trickled from the front of the head, but did not see it.
Thanks,
Old Apr 3, 2013 | 10:03 PM
909wheeler's Avatar
I think the OP means the coolant was on the ground, not the floor of the cabin.
Old May 20, 2013 | 08:15 PM
Well, I have to tell on myself.
1. The tank was topped off full.
2. I ran the engine to operating temp.
3. The overflow hose was directed towards the engine block.
Of course the excess antifreeze was "sparyed" onto the block once I shut the engine down...
Bottom line....No leaking headgasket...just repaired the overflow discharge line.
OUT!
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
stanigu
Jan 24, 2007 05:07 PM
jcostello
Nov 2, 2006 10:28 PM
