Head Gasket Leak-- Crazy (?) Idea ARP Studs
So my wife wants to find a Disco II. I've liked Discos for a long time, so I was on board.
Found one that looked decent and all that, but it's got leaky head gaskets--seller says exhaust ("air") into the coolant.
I also drive a VW Bus that I installed a TDI motor into. It was having a similar leak, though pretty minor. On a chance, I swapped the head bolts out one by one with ARP studs. Those things clamped it down a bit more and sealed the leak right up.
Anyone tried this and had success?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
The chance of success is slim, the cost of gaskets isn’t crazy, so I would just do a head gasket job, which has a lot of steps, but isn’t prohibitively difficult.
A bigger issue is that the block may be cracked. So without having it pressure tested it is a gamble.
Research costs of a good used motor, too.
Thanks!
Thanks!
