Head gasket question
Old Sep 28, 2009 | 06:43 PM
moonman's Avatar
Default Head gasket question
What material is the stock head gasket made of , and are you guys replacing with OEM gaskets or getting something better? Thanks.
Old Sep 28, 2009 | 07:37 PM
Eurotrash's Avatar
OEM are good gaskets. The problem with the gaskets are that owners do not change their oil at the 3000k Mark and the acids in the old oil eat away at the gasket material. Some anti freeze will actack the gasket material. The other problem is the expansion and contraction inherant with sleeve alm. engines rip the gasket. When installing a new gasket ligthly coat the gasket with Permatex 300 gasket sealant which with act as a shere surface.
Old Sep 28, 2009 | 09:34 PM
moonman's Avatar
Thanks.
Old Sep 28, 2009 | 09:42 PM
lipadj46's Avatar
First I've heard someone recommend using any sort of gasket sealant on a Disco head gasket. The OEM gaskets are a composite type gasket. Getting your cylinder heads planed and using new head bolts is the key. Aged Dex-cool and aluminum head warpage are generally the culprits.
Start off with nice clean, straight heads, new bolts and keep your coolant and coolant system maintained and you won't have to mess with your head gaskets again.
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
Tastang
Nov 30, 2007 05:47 PM
jcostello
Nov 2, 2006 10:28 PM
