Head gasket repair
Old Jun 13, 2018 | 04:08 PM
  #21
User's Avatar
What end clamps? Picture would be highly appreciated.
Are you talking about the clamps that hold on the valley pan gasket?
(edit)
I think I got what you mean.
The metal portion does not need to be replaced, only the rubber seals that the clamp puts pressure on
Old Jun 13, 2018 | 04:11 PM
  #22
eskiltell's Avatar
Yes. The valley pan gasket clamps.
Old Jun 13, 2018 | 04:12 PM
  #23
eskiltell's Avatar
Excellent that's saved about 20 bucks at the parts store
Old Jun 13, 2018 | 05:51 PM
  #24
shanechevelle's Avatar
The valve cover bolts should be 12 point 8mm I believe.
My last head gasket, two weeks ago, cost me less than $500.
You dont need to reman pr take your heads to tha machine shop. Check them.
Old Jun 13, 2018 | 06:11 PM
  #25
eskiltell's Avatar
Well unfortunately time ran out today. I got the new water pump in, everything disconnected and unbolted. Now I have to wait till Friday for the gaskets.
I have to say though, the lower manifold bolts were MAYBE alittle more than hand tight, is it safe to maybe use some loctite?
Old Jun 13, 2018 | 07:05 PM
  #26
I snug those up pretty good. I dont torque them to the point of stripping the threads, but they are tight.
Old Jun 13, 2018 | 11:59 PM
  #27
User's Avatar
IIRC lower intake manifold torque is 38 ft lb in a star pattern from middle out.
blue medium strength loctite is welcome and basically any bolt except low torque bolts ie aircon compressor, or alternator which I usually put antiseize
I mentioned remanded heads as machine shops (at least by me) take st shortest a week to get something done. Remanned heads can be mailed in within a day, with all new guides, and a good flat machines surface.
it looks nice as well if you’re one that keeps their Rover looking fresh.
Old Jun 14, 2018 | 10:14 AM
  #28
eskiltell's Avatar
Well today I'm going to clean up the old girl. Is there anything I should be looking for when I pop off the valve covers?
Old Jun 14, 2018 | 10:34 AM
  #29
User's Avatar
Well I suppose the worst would be coolant mixed oil on top of the heads..
Old Jun 14, 2018 | 10:36 AM
  #30
eskiltell's Avatar
True, good thing this weekend I was going to change the oil!
