Head Gasket Repair beginning soon any tips?
Old Dec 27, 2018 | 12:32 PM
Jadden14's Avatar
Default Head Gasket Repair beginning soon any tips?
Im about to start the process for doing my head gasket in my 2004 discovery. It has 110k miles on it and has a rear leak (right about cyl 8) so its time to fix it before it gets worse. I was thinking about the rock auto kit Beck Arnley Head Gasket Kit for 134$ im curious to what others recommend that have worked, as I REALLY do not want to crack the motor again. Also is there anything else I should replace while im working on the motor? everything else works good just curious if there is any other big issues I can address while im down there.
Its been off the insurance currently, but makes an excellent ATV around the yard
Old Dec 27, 2018 | 12:43 PM
zuke's Avatar
V. Rienz gasket set is good. IMO (and my mechanics) just use the stretch bolts. New water pump while you are in there and injector o-rings. I also got new intake/exhaust manifold bolts but probably not needed. Do that PCV mod while you got the valve covers off. New vacuum lines. TB bypass. In-line thermo mod. Go nuts.
Lucky 8 and Ebay are the places to go.
Old Dec 27, 2018 | 02:48 PM
Davis31052's Avatar
ARP head studs
Old Dec 27, 2018 | 09:21 PM
DiscoRover007's Avatar
in addition to previous comments. Make sure you have a good magnet tool with you. The metal rings in the valve covers that the bolts screw into tend to come lose and can fall into the valve springs or in some other random hole if you're not careful.
Old Dec 27, 2018 | 10:04 PM
Frank4's Avatar
Follow the torque sequence to the letter when reinstalling the heads. The head bolts near the firewall on the passenger side are tough to reach, get a couple of impact swivel joints to get at it. Have your heads decked and get a valve job done. Clean up your valve rods and I while you are at it the inside of your valve covers.
Also skip the rook auto kit, go Atlantic British or Lucky8. They are specialists suppliers and the customer service is great.
Old Dec 27, 2018 | 11:41 PM
CollieRover's Avatar
Fel-Pro Gaskets. The rocker cover gaskets are molded.
I recently posted a link to a tumblr blog that lists the tools etc. I used, and sequence of removal. I have some mods so it won’t be to the letter, but a list to go thru anyway. I also wrote a quick summary of challenges/mistakes etc. Change the valve stem seals.
Don’t buy anything Britpart, and do the inline thermostat mod. My only two regrets. Britpart Elbow pipe and Coolant Bottle broke.
Old Dec 28, 2018 | 12:24 AM
No Doubt's Avatar
Your Disco looks good!
What I WISH that I had done was use a dremel to hand grind the exhaust ports on the heads to match the exhaust headers at the inner edge of the exhaust gaskets. So, 1 regret.
What I like that I DID do was:
ground the crank .02 and used .02 oversized rod and main bearings,
used new finished cam bearings and new crower cam+lifters,
machined the heads flat, checked block for flatness,
lapped the valves and verified that they no longer leaked,
replaced the valve stem seals,
used ARP studs,
used Cometic all-metal head gaskets (no more slipped sleeve tick!),
new oil pump gears and timing chain,
honed the liners,
blueprinted the piston ring gaps,
flow-tested the fuel injectors,
JB Welded over my new freeze plugs,
and installed new coils, plugs, and wires.
Perfect idle. Great power delivery. Super smooth revving.
Old Dec 28, 2018 | 10:36 AM
used ARP studs,
honed the liners,
With the exhaust ports enlargened to the size of the gasket the throttle response on the highway is like having a new car. Passing at 70mph plus is now easy. The manifolds restrict the already restrictive head exhaust ports by mm's.
A Dremel will do it, but a good Die Grinder will do it much faster. I used a Makita, but you could get a Chicago Electric to do it, I just did not have a Harbor Freight store near me. I got a carbide bit set that I was too nervous to risk on the head, but it really did a nice job on the manifolds. There are youtube videos on the process, and they are very helpful. You can get sandpaper kits at Harbor Freight, or Summit Racing. But a Dremel will do it, it will just take a while.
And No Doubt, considering your ability to wrench removing and porting the manifolds could be done in a day!
Old Dec 29, 2018 | 08:25 PM
Jadden14's Avatar
Ok I ordered most of my parts now, i have many many tools, however I have an old fashioned torque wrench that doesn't give me an angle reading. Anyone bite the bullet on buying one or is there a place I can rent one? Also in terms of prepping the engine, I'm thinking of spraying pb blaster on any bolts that will be a PITA to get off. Going to try and follow the Atlantic British video closely...
Old Dec 29, 2018 | 11:39 PM
Good ideas. In addition, get a dremel or other tool and without exception, create a thread chaser for every bolt hole and spray brake kleen in all of them and make sure that they are all free of debris.
The aluminum is soft and you can easily strip them and need heli coils.
