Head gaskets look ok
On my way home one day, I noticed My engine temp was way high. Found a dry coolant expansion tank and chocolate milk oil. Figured it was a head gasket
Got everything tore down and to my eye, the gaskets look ok. Do you see anything? The corner that is broken and bent I’m pretty sure was done when I removed everything.
Also, how do my pushrods look to you?
My next concern is a timing chain gasket or cracked block
agree, nothing obvious on the gaskets.
1) Are All liners level with the deck?
2) if coolant got into a cylinder from head gasket leak, the affected spark plug will have brown residue on it.....will point you to involved cylinder
3) hope it is not the block! (miles? type of block?)
The Deputy
16
11-04-2022 07:11 PM
