Head gaskets look ok
Old Dec 8, 2019 | 12:28 PM
blakslee720's Avatar
Default Head gaskets look ok
On my way home one day, I noticed My engine temp was way high. Found a dry coolant expansion tank and chocolate milk oil. Figured it was a head gasket
Got everything tore down and to my eye, the gaskets look ok. Do you see anything? The corner that is broken and bent I’m pretty sure was done when I removed everything.
Also, how do my pushrods look to you?
My next concern is a timing chain gasket or cracked block
Old Dec 8, 2019 | 01:33 PM
XRAD's Avatar
agree, nothing obvious on the gaskets.
1) Are All liners level with the deck?
2) if coolant got into a cylinder from head gasket leak, the affected spark plug will have brown residue on it.....will point you to involved cylinder
3) hope it is not the block! (miles? type of block?)
Old Dec 9, 2019 | 11:24 AM
liners are good. I will double check the plugs
Old Dec 9, 2019 | 11:54 AM
Sixpack577's Avatar
Pushrods are hollow for oil flow.
Make sure they're clear and not gummed up.
Old Dec 9, 2019 | 11:55 AM
thank you. I did not know that
Old Dec 9, 2019 | 11:57 AM
Sixpack577's Avatar
Yes sir
Old Dec 9, 2019 | 08:57 PM
Extinct's Avatar
Disco pushrods are not hollow - they are on sbc and LS engine, but Discos are solid on the ends (hollow if you cut them in half, but the ends are closed).
Old Dec 9, 2019 | 09:00 PM
Sixpack577's Avatar
I looked at mine since and noticed that.
Sorry for bad info
Old Dec 10, 2019 | 07:18 AM
Sorry for bad info
either way, not a big deal to shine em up. Thanks
whowa004
144
Sep 3, 2024 11:02 PM
The Deputy
16
Nov 4, 2022 07:11 PM
dmannrover
Jul 31, 2019 11:57 AM
RoverLover21
Nov 21, 2009 02:41 PM
