Head unit with satellite radio
Old 09-08-2016 | 10:05 PM
huggi's Avatar
Default Head unit with satellite radio
So I kind of miss satellite radio, what aftermarket headunit will fit? Would prefer if it looked a little subdued, not the typical colorful cheap stuff I see everywhere for $70.
Easy install would be appreciated.
Thanks
Old 09-09-2016 | 09:40 AM
OffroadFrance's Avatar
Thanks
Most head units are standard DIN sizes so many will fit. I keep the Becker unit with autochanger but I'm sure there are many others that will fit the aperture. Worth a trip to a reputable car audio store for a combination radio, satnav, CD player unit. Take a look around the store as the bigger stores have them ready mounted for demo purposes with the spec and prices attached.
Old 09-09-2016 | 10:39 AM
drowssap's Avatar
If you want to give up the CD player there are adapters that will allow to use the stock head and steering wheel controls.
Old 09-09-2016 | 11:21 PM
haasri's Avatar
Default here is one
Select Language
  • Delphi Bluetooth and Satellite Radio Integrated Kit
Add to CompareVIEW MY COMPARE PRODUCTS (0)
ADD TO WISHLISTEMAIL A FRIEND
PanaPacific
PART NO: PP805352
REPLACES OLD PART NUMBER(S):
PP103802
Product Features:
PP105715 Radio Features:
  • Heavy-Duty Design specifically made for a commercial vehicle driver by having larger buttons and a heavy-duty construction for tougher environments
  • Integrated SiriusXM Satellite Radio Tuner – offers 100+ channels of digital quality audio programming heard uninterrupted across the continuous United States; a subscription is required to receive satellite broadcasts
  • Built-in Bluetooth® for hands-free cellular phone operation- up to 10 Bluetooth® devices can be easily stored in the radio memory for fast pairing
  • Bluetooth® Audio Streaming
  • Weatherband (WB)- offers 7 weather band frequencies/channels free of charge to provide you with the continuous weather information 24/7
  • ISO Connector – allows the radio to be connected directly to the vehicle’s harness; no other harness is required – no cutting, no separate accessories to purchase for vehicles manufactured with the ISO connect harness
  • Front Auxiliary Input (Music Port) – plug in a smart device to enjoy your music through the vehicle’s speakers
  • Front Panel USB Port – gives a direct connect location for memory devices with USB interface, to play stored music and/or charge the device and to have iPod® control through the radio
  • Rear Auxiliary Input – provides and auxiliary terminal for permanent hard wire to the rear side of the radio
  • SAE J1455 Compliant – meets the test standards for commercial vehicles
  • SAE J1939 Compliant – allows the different vehicle components that run on the communication bus system to talk to each other; compatible with most digital steering wheel/rear-sleeper controls*
  • CD Player
  • Output Power: 18 Watts x 4 Channels
  • Sound Quality (EQ) Function – select the sound type (Pop, Rock, Country, News, Jazz, Classical or Manual) to improve the dynamic range of your listening music type
  • Separate Bass, Mid, Treble, Balance and Fader Controls – adjust the mode according to your preference
  • Back-lit Display Lighting – Switchable between GREEN or AMBER
  • 6 AM/12 FM/18 SAT Radio Preset Buttons
  • Built-In Quartz Alarm Clock with One Hour Timer
  • Auto Store Memory
  • Handheld Remote Control sold separately – Part No. PP603988
**Digital Sleeper Control Module sold separately- Part #. PP803750 or PP104245
Microphone Product Features:
  • Allows hands-free phone calls with the Bluetooth® feature of this radio
  • Designed to be secured to a surface by use of double sided adhesive tape and is 3/4″ wide by 1-5/8″ tall; it does not need any sort of hole in the instrument panel
  • The 7.5′ cable includes a connector that plugs directly into the back of the radio
$299.64
QUANTITY 1 2 3 4 5 6 7 8 9 10QUANTITY
Add to Cart
Tahoe Linder
Audio/Visual Electronics
02-05-2008 07:19 PM
harry_123
08-16-2006 05:07 AM
kidsdoceks
04-14-2006 01:15 AM
fidel309
12-17-2005 02:04 PM
rlpayne
11-16-2005 04:22 AM
Quick Reply: Head unit with satellite radio
