Head unit with satellite radio
So I kind of miss satellite radio, what aftermarket headunit will fit? Would prefer if it looked a little subdued, not the typical colorful cheap stuff I see everywhere for $70.
Easy install would be appreciated.
Thanks
Thanks
Most head units are standard DIN sizes so many will fit. I keep the Becker unit with autochanger but I'm sure there are many others that will fit the aperture. Worth a trip to a reputable car audio store for a combination radio, satnav, CD player unit. Take a look around the store as the bigger stores have them ready mounted for demo purposes with the spec and prices attached.
If you want to give up the CD player there are adapters that will allow to use the stock head and steering wheel controls.
Select Language
Add to CompareVIEW MY COMPARE PRODUCTS (0)
ADD TO WISHLISTEMAIL A FRIEND
PanaPacific
Delphi Bluetooth and Satellite Radio Integrated Kit
PART NO: PP805352
REPLACES OLD PART NUMBER(S):
PP103802
Product Features:
PP105715 Radio Features:
Microphone Product Features:
$299.64
QUANTITY 1 2 3 4 5 6 7 8 9 10QUANTITY
Add to Cart
- Delphi Bluetooth and Satellite Radio Integrated Kit
Add to CompareVIEW MY COMPARE PRODUCTS (0) ADD TO WISHLISTEMAIL A FRIEND
PanaPacific
PART NO: PP805352
PP103802
Product Features:
- Heavy-Duty Design specifically made for a commercial vehicle driver by having larger buttons and a heavy-duty construction for tougher environments
- Integrated SiriusXM Satellite Radio Tuner – offers 100+ channels of digital quality audio programming heard uninterrupted across the continuous United States; a subscription is required to receive satellite broadcasts
- Built-in Bluetooth® for hands-free cellular phone operation- up to 10 Bluetooth® devices can be easily stored in the radio memory for fast pairing
- Bluetooth® Audio Streaming
- Weatherband (WB)- offers 7 weather band frequencies/channels free of charge to provide you with the continuous weather information 24/7
- ISO Connector – allows the radio to be connected directly to the vehicle’s harness; no other harness is required – no cutting, no separate accessories to purchase for vehicles manufactured with the ISO connect harness
- Front Auxiliary Input (Music Port) – plug in a smart device to enjoy your music through the vehicle’s speakers
- Front Panel USB Port – gives a direct connect location for memory devices with USB interface, to play stored music and/or charge the device and to have iPod® control through the radio
- Rear Auxiliary Input – provides and auxiliary terminal for permanent hard wire to the rear side of the radio
- SAE J1455 Compliant – meets the test standards for commercial vehicles
- SAE J1939 Compliant – allows the different vehicle components that run on the communication bus system to talk to each other; compatible with most digital steering wheel/rear-sleeper controls*
- CD Player
- Output Power: 18 Watts x 4 Channels
- Sound Quality (EQ) Function – select the sound type (Pop, Rock, Country, News, Jazz, Classical or Manual) to improve the dynamic range of your listening music type
- Separate Bass, Mid, Treble, Balance and Fader Controls – adjust the mode according to your preference
- Back-lit Display Lighting – Switchable between GREEN or AMBER
- 6 AM/12 FM/18 SAT Radio Preset Buttons
- Built-In Quartz Alarm Clock with One Hour Timer
- Auto Store Memory
- Handheld Remote Control sold separately – Part No. PP603988
- Allows hands-free phone calls with the Bluetooth® feature of this radio
- Designed to be secured to a surface by use of double sided adhesive tape and is 3/4″ wide by 1-5/8″ tall; it does not need any sort of hole in the instrument panel
- The 7.5′ cable includes a connector that plugs directly into the back of the radio
$299.64
Add to Cart
Tahoe Linder
Audio/Visual Electronics
Feb 5, 2008 07:19 PM
