Headgasket
Old Jan 21, 2009 | 03:12 PM
dionblake's Avatar
Default Headgasket
Hello all, 1st time posting in here but daily reader & 2x Disco owner. Gotta question for all.
03 Disco 106k miles on it slow coolant leak, ( never overheated) in 2yrs. replaced gaskets at thottle body last yr. Now notice slow leak at bottom. My mechanic checked it out this week & looks like blownhead gasket @ the rear corner driver side. He is willing to fix but 1st question is this. 1st off he is a master "A" tech w/ 39 yrs on motors of all kinds but only touched LRS a few times doing timing belts & such. His concern is that job is listed @ 12hrs for both & he thinks it can be done in a lot less time, soooooo whats under there that is going to take him a while or throw him for a loop? basic question is this #1 the guy knows engines but not saavy on LRs is there anything he is going to run into that will throw him for a loop? parts, screws, nuts, equipments that only the dealer has? any special rover quirks that he should know when doing this please advise guys.
Thanks
Old Jan 21, 2009 | 03:30 PM
jkid's Avatar
Default RE: Headgasket
It's your basic simple pushrod engine, nothing special. There's just a lot of stuff that has to come off, 12 hr is probably about right. It probably took me about twice that but I was in no hurry and I tore the rocker arm assembly down to, plus the valve seals took sometime. Make sure he gets an intake gasket set.
Old Jan 21, 2009 | 03:50 PM
Normal parts and labor on your engine with secondary air, head work excluded if needed, is apx. $1500
Old Jan 21, 2009 | 05:58 PM
Jeff In Katy's Avatar
Where are you located?
Jeff
Old Jan 21, 2009 | 06:11 PM
ORIGINAL: dionblake
Thanks
The only LR with a timing belt is the FreeLander and that has a BMW engine.
Like Jkid said, this is a simple engine, it is build just like a Chevy 350 only it says LR on the hood.
Old Jan 21, 2009 | 08:10 PM
dionblake's Avatar
parts & labor will be well under1500, & he is aware of all basics such as intake gasket change out & bolt change out,just any otherr quirks is what I am checking for for him before he starts. But it sounds this this is a simple job & it should not present any problems
Old Jan 21, 2009 | 08:12 PM
dionblake's Avatar
btw i meant serpentine belt not timing. i am in jax fla
Old Jan 22, 2009 | 09:29 AM
Change out the t/stat, use Dexcool only, if replacing the belt, also ereplace the belt tensioner and both idler pulleys.
Old Jan 22, 2009 | 11:55 AM
gone postal's Avatar
6th Gear
Will you PM me his name & contact info please? I live in St Aug and although not a LR owner yet, I plan to relatively soon. I plan on doing most if not all of my work myself, but it can't hurt to have a backup # of a reputable guy.
Old Jan 22, 2009 | 12:20 PM
dionblake's Avatar
Disco Mike, are you saying to replace thr belt & do those things? cuz belt was just replaced 1yr ago now with tune up @ 100kOR are you saying if I make those changes I should ensure I do those chnage outs?
