Headlight Basics?
Old Sep 24, 2017 | 08:59 PM
No Doubt's Avatar
Originally Posted by No Doubt
what's the step by step guide for aiming the lights? My low beams seem aimed just a tad too high for traffic.
On 2003's (and probably 2004's) there are 2 black plastic OEM brackets that connect to the headlights.
Each bracket has 2 bolts and 2 phillips screws.
I adjusted my headlights by loosening only the two bolts, which then allowed me to tilt the entire headlight (and bracket) up or down ~~1 degree, then you tighten those two bolts back (the bolts will tighten in a slightly different position based on how much you moved the bracket+headlight to adjust your beam).
Easy. Don't mess with the 2 phillips screws when your sole purpose is adjusting headlamp angle. Those 2 phillips screws are for connecting a headlight to the black plastic bracket.
The 2 bolts connect that bracket to your Disco...and sliding that bracket slightly forward or backward on your Disco before tightening those 2 bolts will adjust your headlight beam up or down as desired.
Push the bracket toward your driver seat and that tilts your beam up a bit.
Pull the bracket away from your driver seat and that tilts the beam down some.
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
Henkman
Oct 14, 2005 02:48 PM
igriego
Jun 25, 2005 08:48 PM
