Headlight and foglight recommendations?
Looking for a brigther, whiter alternative to factory replacements. I'm a novice at the replacement light game. Can someone recommend an effective option?
Thanks.
Thanks.
Other than going to HIDs, these are probably the brightest you can get.
Amazon.com: Sylvania 9003/HB2/H4 SZ SilverStar zXe High Performance Halogen Headlight Bulb (Low/High Beam), (Pack of 2): Automotive
I just put a set on my other car, and they are noticeably brighter than stock. However, there is a tradeoff as many will tell you, these do not last long. (Sylvania says they should last about a year). And they are expensive.
This may be a silly question, but for the 03/04 discos, is the smaller inset light for a separate high beam bulb? When I bought the truck, it was missing those bulbs, so the high beams don't work. If that's the case, I assume I would get a different bulb than the ones linked by James b/c I wouldn't want/need high and low beam capabilities in a single bulb. Right?
I don't plan on switching to HIDs. I just need replacement high bulbs since mine are missing and new fog lights bc the LEDs the PO installed are a waste of lumens. So my primary intent is good lighting, with just a touch more white to modernize the appearance just a bit.
For the low and high beams, Silverstar Ultra's offer a brighter output, without the blue tint that results in reduced inclement weather visibility. The Silverstar zXe's are awful in the rain and fog.
For the fog lights, Hella Optilux XY series. They're about as close to Selective Yellow as you can get nowadays, and that's the best color to run for a fog light being used in rain or heavy snow to give you some contrast on the ground.
