Headlight housing issue
Good Day,
Driver side low beam bulb went out, so I started the process to change them both and immediately ran into trouble. On the driver's side housing, screw 'A' spins but does not come out (it won't tighten back up, either), and screw 'B' is stripped (the screw drive part) so I can't even try to turn it.
Are there any other ways of removing the larger housing, perhaps by loosening the torx head bolts?
Just to make matters worse, the side bracket on the passenger headlight housing is broken altogether, so I'll need to either epoxy it, or get a replacement housing.
Thanks in advance.
Thanks in advance.
I hope it's me that is confused. From the diagram in the manual, it looked like the screws. The Torx look intact, at least. Thanks!
