headlight problem
Old Dec 2, 2012 | 02:07 PM
starcraft1's Avatar
Default headlight problem
Last night I discovered that my headlights have stopped working. No problems with the fuses and the high beams still work. When i turn the dial the dash lights come on and i noticed that when I move the dial to full headlight mode that the dash lights dim as if power is being sent to the lights. Any ideas? I cant believe that both bulbs blew at once but i guess its possible. Thanks
Old Dec 2, 2012 | 03:31 PM
lr2001silver's Avatar
Banned
Its very possible and quite a seen quite a few times here.
Old Dec 2, 2012 | 06:56 PM
aarongregor's Avatar
As lr2001 said it is possible, I know first hand because both mine blew at the same exact time.
Old Dec 4, 2012 | 07:01 PM
starcraft1's Avatar
Ok so i was down at advanced auto and was about to buy some new bulbs. However, when i went to pay i asked the guy if the headlights and high beams come from the same bulb and he said yes. Now these guys arent always the sharpest so i figured i would check with you fine folks. If they are from the same bulb i have problems because the high beams still work. Any thoughts?
Old Dec 4, 2012 | 07:31 PM
dgi 07's Avatar
Same bulbs, different filament.
Use some gloves when installing. Dont touch the bulbs with your bare hands.
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
mfryburg
Oct 19, 2008 10:38 AM
incubus
Aug 30, 2007 09:23 AM
