Headlight Screw Part #?
Old Aug 29, 2009 | 11:05 PM
akbarkhan's Avatar
Default Headlight Screw Part #?
Hi all,
My left headlight is out, and I was trying to get the two screws holding the headlight assembly out, but one of them is completely worn away. I think I can still get it out, but I'd like to replace all four of them.
Did a search on the forums, and the RAVE manual...but no luck. Anyone happen to know the part number, or a screw size for replacement. Thanks in advance.
Old Aug 30, 2009 | 08:10 PM
akbarkhan's Avatar
After fighting with the screw for about 2 hrs...decided to cut the plastic around the screw connecting to the headlamp assembly. Popped right out, and now using a large rubber washer to fill in the space.
As for the screws, I spent a good amount of time crawling around the bins at the hardware store and got three different sizes for 11 cents a pop. Not sure of the size, but a perfect fit. I'll check on the sizes, and post here in case anyone has the same problem.
Thanks all
Old Aug 30, 2009 | 09:10 PM
lipadj46's Avatar
Most any screw of about the right size will work because the hole is not really threaded like a proper nut or threaded bolt hole.
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
BrandonS
Dec 17, 2012 09:55 PM
Disco03
Dec 1, 2008 08:08 PM
