headlight swap
Old Mar 17, 2017 | 04:27 PM
LRD2rangel's Avatar
Default headlight swap
evening,
can the headlights from an 2003 disco be put on an 2001?
Old Mar 17, 2017 | 09:12 PM
emncfi's Avatar
Few write ups on it running around the Internet, I did mine using a couple different guides. The only issue I had was a few of them had different color wires than mine in the wiring diagram. There is metal cutting (a little) and some creativity needed to hold the lights in place. The lower smaller headlight in the bright beam, and it is on along with the regular beam when the brights are on. Doing that requires a relay to be wired in. If you attempt it and get confused many have done this mod and can help you out should you get stuck (myself included)
Old Mar 23, 2017 | 06:44 PM
Big Jim Swade's Avatar
I've thought about it too, but the cost to do it correctly is way too expensive. I'd change out the front bumper too and I think it would be cheaper just to sell my 01 and buy an 04. I decided to just live with my 01.
Old Mar 24, 2017 | 07:27 AM
Frank4's Avatar
Originally Posted by LRD2rangel
evening,
As stated above it can be done but why go through all that trouble only to have your headlights fog up or turn yellow? I like the ones that came stock on my 2000, they require no maintenance and will be clear forever.
sam1234
Mar 19, 2018 03:22 PM
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Eak69
Sep 21, 2010 02:01 PM
Disco03
Dec 1, 2008 08:08 PM
