Headlight washer not working.
And still tracking down things that don't work on the new truck...
The headlight washers don't seem to be working. The #4 fuse was blown, but I've replaced it and it hasn't blown again (yet).
Kind of hoping it's just frozen (no idea what fluids have been in it) and that with the new fuse and some warm weather it will work it's self out.
Still I'd like to get a look at the pump and see if it's seized, see if it's getting power, that kind of thing. But so far I just can't lay eyeballs on it, seems to be truly buried under all that plastic… is there an easy way to access it?
Sucks to try and get at things in winter in Toronto without a garage... may have to wait till spring. But I'm open to suggestions!
N.
N.
N.
N.
Thanks guys. I don't think I realized it only happened with the lights on, but makes sense now you say it. So my check of it probably didn't activate it. Willing to bet the fuse is blown again now that it has been used with the lights on (I'll check tomorrow).
Yes, I found it all in the rave (but thanks for the heads up anyway), was really hoping it wouldn't entail removing the bumper cover to just get a look at.
Maybe it will work it's self out... or in the spring…
Not mission critical I suppose.
I thought mine didn't work as well until I googled it and you are right it is every third time you use the washers "with the lights on" and that is key ...the lights have to be on or they wont work.
tsuyoi
09-22-2020 10:37 AM
