Headlight Washer Schematic
Hey guys, I pulled the drivers side panel off of the wheel well. I can't seem to figure our why there are two hoses. The schematic in the RAVE book doesn't show the complete hose configuration.
The two hoses that go across to the passenger side are in the right spot, but I seem to have two thinner hoses on either side of the car...connecting to nothing. Any help would be great.
Yep, those 2 hard plastic (as opposed to softer rubber for the washer fluid) are for the fog lamps. Basically... when you drive thru water (wading!) if the fog lamps are on and hot, they'd explode ! So... these are basically breather tubes to relieve pressure in the fog lamp housing so that doesn't happen. They are open to air at the end just like they are in your above pic
Oh, I think still confused. There is a rubber tube that should be in the bottom of the washer fluid reservoir, so the fluid can get over to the headlamp washers in the bumper. Is that what you mean?
For the fog lamps, the other end should be shoved in the back of each fog lamp assembly. This is helpful diagram here -- https://landroverforums.com/forum/di...l-water-52947/
Sean Winter (08-12-2022)
yep, excellent. I forgot to mention (And the diagram you posted reminded me), for anyone else looking at this, the hard plastic tubes that go into the fog lamps actually are connected to the fog lamp via a short length of rubber flexible tubing (which makes it all a bit even more confusing!)
