Headlight wiring malfuction /the wipers come on.
![Thumbs up](https://landroverforums.com/forum/images/icons/icon14.gif)
I've been to this site a few times and always get good info. This issue is a doozy because my Rover is down. When I turn on the headlights, the wipers come on. Not to long ago I replaced that switch and maybe this is the side effect. Anyways there seems to be a wiring issue and I'm up for any suggestions on how to fix this wiring problem.
The headlights do come on but I cant drive it at night because when I turn the lights on the wipers come on also. So I just pull the wiper fuse to disable them and keep going. I forgot to mention that the turn signals are also not working now, and the hazard lights. Things are getting worse very fast.
I want to say yes i did disconnect the battery but. I'm not sure. I talked to a Rover mechanic and he said I shouldn't use used parts and should have put in a new headlight switch. U never know what you get with a used part. Now im going out to take off the wiper switch to test and see if thats causing the problem.
gmfain
02-16-2015 09:37 AM
wastedincome
11-27-2012 08:05 PM
