Headliner sagging
Old Apr 25, 2019 | 01:14 PM
Shad Whitten's Avatar
3rd Gear
Default Headliner sagging
Hey people. New here. But wondering how many of you have had your headliner start to sag and how you approached the repair? Did you go to a Professional? If so, what was the approximate cost? Easy enough DIY? Thanks for any input.
Had my 04 SE for about 4 years now. It’s been a both good rider and a pain in the *** as well. Hopefully getting her back to a daily soon.
Old Apr 25, 2019 | 02:06 PM
Davis31052's Avatar
I recovered mine. Most folks just remove the cloth and foam then paint it.
there is a write up in the sticky's up top
Old Apr 25, 2019 | 02:55 PM
Dave03S's Avatar
A professional recovering is around $600, Just inquired at a shop in Portland, Or.
Old Apr 25, 2019 | 03:20 PM
3rd Gear
been reading those. Just not sure I have the time but definitely would love to do it like that.
Old Apr 25, 2019 | 03:21 PM
3rd Gear
thats not too bad. I’ll have to call around for LA prices. Thanks.
Old Apr 25, 2019 | 03:30 PM
Bignacio's Avatar
In Orange County CA, UNION JACK 4X4 does them for about $250. I got mine done there...
Old Apr 25, 2019 | 07:32 PM
Externet's Avatar
Can be fixed/renewed/replaced with enough money.
If not in too bad condition, my way is with a fatty-enough-to-flow syringe with white 'school' glue. Go trough the fabric and guess-insert a drop of it; press/prop with a sponge for a while. When the glue dries, do another spot. Do not use too much glue, many grains of rice size spots work better than a larger blob, and do not show.
At least there is nothing to lose if you try.
Old Apr 25, 2019 | 09:45 PM
mollusc's Avatar
glue like that can make for big headaches if you eventually decide to do something different like strip off the fabric and paint it. the glue residue is often really hard to remove.
Old Apr 26, 2019 | 06:32 AM
slanginsanjuan's Avatar
there's probably a leak somewhere that's gonna need to get fixed. it only gets worse. much worse.
Old Apr 26, 2019 | 06:36 AM
mln01's Avatar
Yes the sunroofs leak, but unless there are water stains evident that may not be the cause here. The headliners sag because the foam layer in between the fabric and the fiberglass shell disintegrates over time. That's a big reason I painted mine; it can never sag again and it looks great.
