Headliner: tear down for new fabric
Old Nov 6, 2020 | 03:16 PM
  #21
WaltNYC's Avatar
Here is a good thread for anyone giving it a try. I've done two. Use a wire brush to remove foam. Apply glue to both fiberboard and material. Allow it to set for a couple of minutes. Start from the middle and work outwards. Take your time. Leave enough overlap to glue the excess to the other side of the board which helps keep wind from tearing the foam away from the cloth.
https://landroverforums.com/forum/di...76/#post191929
Old Nov 9, 2020 | 12:21 PM
  #22
escott16's Avatar
Originally Posted by Saturnine
I second the painting route. Really easy to do and looks good enough. Just rip off the fabric, and use a wire brush to remove the left over foam. Its a messy job so be prepared to clean up. I wiped it down with rubbing alki as best i could before painting. Went to home depot with a plastic trim piece and they matched me a gallon of interior paint (might have been exterior, can't remember) Two coats was all it needed.
Consider doing some insulation while the head liner is out.. again, super easy.
How much material did you need for the roof? i ordered the same exact stuff for a different project i just forget how much i was able to cover
Old Nov 9, 2020 | 12:26 PM
  #23
baileyrockhound's Avatar
Originally Posted by Richard Gallant
Do you have the fabric size you used
you need a 60" wide fabric x 3 yards
Old Nov 9, 2020 | 12:29 PM
  #24
escott16's Avatar
Im sorry i meant the sound deadening material, Sorry should have clarified
TyTyBinks
Jul 1, 2020 10:23 AM
whiskeynipple0088
Feb 24, 2020 09:57 AM
BrandonG83
Apr 30, 2015 02:47 PM
Ross Landiepanzer
Jan 7, 2013 04:55 PM
discoguy
Jun 22, 2008 04:00 PM
