Heated Front Screen
Old Nov 30, 2024 | 02:19 PM
Daytoman's Avatar
My Indy shop already turned on the heated windshield timer for me….
unfortunately when I pulled the blank switch button there was no wiring harness plugged into it. Interestingly enough the two other blank switches for the fuel door release button and the rear air suspension did have wiring harnesses plugged in…. So out of curiosity, I want to my 2003 HSE and pulled the blank button for the front windshield and there was a wiring harness attached, however there was no wiring attached to the blank fuel door release button CRAZY! 😂
2004 SE
2004 SE
2003 HSE7
2003 HSE7
Old Nov 30, 2024 | 02:21 PM
Daytoman's Avatar
Originally Posted by longtallsally
Did you pull the entire switch pod out? When I added to my ‘04 a while back, this is what it looked like with the blank in there:
Also, you’ve got a Nanocom or the like to do the programming, correct?
I did not pull the entire switch pod out. How did you get that out of there? My last hope is maybe that it was never plugged in or maybe It came unplugged and is hanging around back there.
Old Nov 30, 2024 | 03:13 PM
Daytoman's Avatar
I got the pod out and that windshield plug is literally the only one that is not plugged in and the only one that’s not coming out of the wiring loom…. Bummer.
Old Dec 1, 2024 | 09:51 AM
longtallsally's Avatar
Check the reply I put in to your thread. I think you might have to pull the entire center fascia to look for it. Again, I bet it’s there and just hidden.
mill686
Feb 4, 2014 08:09 PM
tja
Sep 14, 2010 03:54 PM
G4AKumar
Feb 26, 2010 04:33 PM
AspenRover
Audio/Visual Electronics
Dec 29, 2008 08:36 PM
MercadoRR
Sights N Sounds
Mar 17, 2006 05:00 PM
