Heated Seats
Old Feb 8, 2007 | 05:36 PM
Default RE: Heated Seats
Don't waist your money on a steering guard, Assuming you have a little lift the only bad spot is the tie rod and it takes a little to hit it.
I would rather see you put some money into a set of diff guards.
As for recovery points on a D2, good luck, there really is no secrure spot for 2 hooks that will not damage your bumper when you are being towed. Here again, might want to save up and go for a good front bumper with recovery points.
Mike
Old Feb 9, 2007 | 09:08 PM
wielgoshoff's Avatar
4th Gear
So, I have a 97 Discovery with Leather interior... are you saying that I could have toasty buns? Or is this just for thhe Series 2 Discos?
Thanks,
Eric
Old Feb 9, 2007 | 09:14 PM
I believ it is on the D2's only, I don't reemember D1's haveing heated seats.
Mike
Old Feb 13, 2007 | 04:29 PM
4th Gear
So everyone knows, I have a 97 Disco 1 with leather interior. I took out the wiring console where the power windows are, and lo and behold: Disco 1s with leather interior are indeed wired for heated seats! The $49.95 kit at Atlantic British, and my butt is warm!
Old Feb 14, 2007 | 06:20 AM
optima's Avatar
4wd High
I'm still waiting for my switches should be in sometime this week....
Old Feb 14, 2007 | 11:05 AM
ORIGINAL: wielgoshoff
Thanks for the feed back, I stand corrected, glad to hear there may be some more happy faces coming from the inside of their truck thats to the bun warmers.
Mike
Old Feb 15, 2007 | 07:00 PM
optima's Avatar
4wd High
Hi all
So my switches arrives today, and istalled them and i've still got a cold bum So after a little more checking do any of you will warm bums have a fuse box under each seat with a 40amp fuse in ??? because i dont have that bit and also do your cables connect into a brown block connector which is by the CD changer and ECU ???
Hoping for a bum at some time in my life because I think the yellow leads in the pictures i posted are maybe for a seat belt tension
booper169
Nov 9, 2010 09:10 AM
tophetec
Dec 2, 2006 01:03 PM
newBrover
Nov 14, 2006 12:50 PM
sydneysport
Oct 1, 2006 09:18 PM
sydneysport
Sep 24, 2006 11:33 AM
