Heated seats?
Heated seats?
I just installed new heated seat switches in my Disco 2 and I couldn't really tell if they were working properly. So I used my friend's flir camera and it looks like the passenger seats working but not the driver's side. How hot do the seats suppose to get, hot-hot or semi-hot or just warm? Thanks.
Right, they are NOT supposed to burn your butt!!!!
You have a crimp in your seat heater wiring if your getting a hot spot, which is caused by a higher resistance at the crimp. The heat seater is a low resistance circuit. Any disturbance leads to a higher resistance which will immediately lead to excess heat dissipation in that area.
When you take the seat apart you can see the brown or black markings of the hot spot and search for the compromised wire in that area. You can jump the open with a wire soldered to either end or just trying to resolder the broken pieces.
Or more simply replace the entire lower element. A new element is about $60 last time I checked.
booper169
11-09-2010 09:10 AM
sydneysport
10-01-2006 09:18 PM
sydneysport
09-24-2006 11:33 AM
