Heated seats, anyone thought of.....
RE: Heated seats, anyone thought of.....
Speaking of heated seats, yesterday was the first time I tried my heatedseats. "Holly cow Batman"that sucker got warm an cozzy. That was my first time sitting in a heated seat soI have nothing else to compare it with. The only thing that was missing is a massage optionand it would feel like a lazy boy chair.
I do have one question, once you turn on the heat, is it on a timer or thermosatically controled? It seemed if it was left on for a long time the seats (an its circuit) would get rea hot and a timer or thermostat would protect the circuit.
ORIGINAL: Urban Panzer
They are thermostatically controlled. Once they are up to temp, they stay at that temperature.
The ones I had In my A8 had 6 settings, on 6 you was boiling your assss [:@]
The temperature control unit is only fitted to vehicles with electric seats. Feed back of the seat temperature is via a
Negative Temperature Coefficient (NTC) sensor within the seat cushion. Resistance of this sensor changes with the
temperature of the seat cushion allowing the temperature control unit to lower or raise the voltage to the seat heater
elements to raise or lower their temperature.
An ignition feed is supplied via the seat heater switch. The temperature sensor supplies an input. Output is a supply
to the cushion heater element and an earth.
Thermostat
On vehicles with non electric seats, the temperature is controlled by a thermostat located in the seat cushion. The
thermostat interrupts the power supply when it reaches a pre-determined temperature.
The temperature control unit is only fitted to vehicles with electric seats. Feed back of the seat temperature is via a Negative Temperature Coefficient (NTC) sensor within the seat cushion. Resistance of this sensor changes with the temperature of the seat cushion allowing the temperature control unit to lower or raise the voltage to the seat heater elements to raise or lower their temperature. An ignition feed is supplied via the seat heater switch. The temperature sensor supplies an input. Output is a supply to the cushion heater element and an earth.
Thermostat
On vehicles with non electric seats, the temperature is controlled by a thermostat located in the seat cushion. The thermostat interrupts the power supply when it reaches a pre-determined temperature.
Thermostat
booper169
11-09-2010 09:10 AM
bosshogt
08-27-2010 09:35 PM
sydneysport
10-01-2006 09:18 PM
sydneysport
09-24-2006 11:33 AM
adjust, coefficient, correct, discovery, element, heated, heater, heating, ii, landrover, negative, resistance, seat, seats, temperature
