heated windshield problem
Old Jan 7, 2013 | 01:50 PM
BTamas's Avatar
4th Gear
Default heated windshield problem
My Discovery 2 (2003 my) heated windscreen is not working very well. Now there are two vertical areas about 2 cm wide that aren't cleared when I turn it on. Can anyone suggest a resolution, or should I change the windshield for a new one?
Thanks!
Old Jan 7, 2013 | 01:57 PM
Fallstaff's Avatar
That's the windshield its self. Nothing you can do about that but replace it.
Of course at that size, I'd just recommend getting over it. It's an expensive part!
Old Jan 7, 2013 | 03:03 PM
lr2001silver's Avatar
Banned
Open your hood and look for the connections at each bottom corner of windshield, make sure they are plugged in all the way if good there then your windshield it self is failing.
Old Jan 7, 2013 | 06:52 PM
You have some chips or cracks that have broken some of the heater element wires. Only way to fix it is replace it.
Old Jan 8, 2013 | 12:55 AM
Yep, the plugs are only two wire, the tiny elements are divided up into columns inside the glass itself. I recall one post where a member had a turkey fly up and strike his windshield, and it was covered by insurance.
Old Jan 8, 2013 | 01:39 PM
BTamas's Avatar
4th Gear
Thanks to everybody for the replys, I wait another winter before replace it, it is still working about on 80% of the surface.
Thanks
PKG Vitesse
Nov 27, 2011 08:07 PM
hpipe
Dec 12, 2008 09:06 AM
BostonBB
Oct 9, 2007 05:32 AM
wimp
Oct 28, 2006 05:17 PM
