Heater always on...
Old Oct 23, 2014 | 12:04 PM
RipD's Avatar
Default Heater always on...
(Not sure if this belongs here or in general tech. Let me know if I should move.)
My 2003 Disco seems to have floor heat always on. The only exception is when the A/C is running. Have taken it to dealer multiple times and their opinion is that it's heat coming off the transfer case. That's not it. My RR classic had a lot of transfer case heat - I get that. This is different. I have heat coming out of the floor vents all the time the A/C is not running.
Heat and a/c work fine otherwise. I'm guessing water is flowing through the heater core all the time. Is this possibly a stuck heater core valve?
Old Oct 23, 2014 | 12:08 PM
drowssap's Avatar
A DII does not have a heater control valve, even when off heat still goes threw the heater core, even in AC heat still goes threw the heater core.
the only way to stop it other than installing a control valve is to turn the temperature setting down to a colder setting.
Old Oct 23, 2014 | 12:31 PM
RipD's Avatar
Got it. I still get heat all the time. Thermo is almost always on low setting unless it's very cold out. For example, when it's 70 degrees out and I have everything set to Lo, the only way to not get heat is to turn on the a/c.
Old Oct 23, 2014 | 03:53 PM
It's tech question about a Disco II so your in the right place
Old Oct 24, 2014 | 06:09 AM
drowssap's Avatar
or set it on cool and hit the econo button the will kill the ac compressor.
but without a heater control valve you can not stop it,
if it bothers you that much you could install a universal control valve off ebay for like $30.
Old Oct 24, 2014 | 10:57 AM
RipD's Avatar
The issue is that the Econo button = heat in my truck. There doesn't appear to be any way for me to get any venting without the air being heated, regardless of the outside temp or where my thermo is set.
I'll take a look at the universal control valve. Thanks for the tip.
Old Oct 24, 2014 | 11:32 AM
drowssap's Avatar
you need something like this:
HVAC Heater Control Valve Shut Off Valve 4 Seasons 84707 | eBay
ls1morethanyou
Jan 12, 2017 10:21 AM
mcwilly21
Oct 14, 2009 07:40 AM
salers4
Freelander
Jul 21, 2007 12:48 AM
dcarsmith
Mar 8, 2007 10:16 PM
nuno106
Oct 30, 2006 03:31 PM
