Heater blows cool air when idle?
Old Nov 9, 2018 | 08:56 AM
Berenice.amezcua17@gmail.com's Avatar
Default Heater blows cool air when idle?
My heater on my disco 2 blows out cold air unless vehicle is moving. I am very concerned about this because last time this happened the head gaskets went out. I just got them places 2 years ago. Can they possibly be going out again? I've checked my coolant and it is full, and the disco has not overheated since two years ago when the gaskets went bad.
Old Nov 9, 2018 | 10:07 AM
Richard Gallant's Avatar
Could be the heater core if it is clogged it take more pressure to move the water through it. It could also be the water pump if the impeller is going you get less flow at lower RPM.
Are the hoses going to the heater core hot - both of them ?
Do you know your engine temps or just use the dash gauge ?
Old Nov 9, 2018 | 11:19 AM
I only use the gauge on the dash, how can i check the actual engine temp?
Old Nov 9, 2018 | 11:44 AM
Jason_B's Avatar
You can buy a device called a scan gauge or ultra gauge.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
UltraGauge OBDII Scan tool & Information Center
It is very easy to install: you just plug it into the OBDII under the dash. Takes about 2 min. You should be seeing temps around 188-204.
Old Nov 9, 2018 | 02:10 PM
The Deputy's Avatar
If you're getting heat while the engine is running at higher rpm...then most likely it's a flow issue...not temp issue. Obviously, you have a high enough engine temp to give you heat (while moving), so it is either a partially plugged heater core or water pump or blockage somewhere else. Most likely...heater core...especially, if you don't know previous history of vehicle and what's been dumped in the cooling system over the years (stop leak product)...or if it has sat for a long period of time. Remove both hoses and back flush the heater core...would be the best place to start.
Old Nov 9, 2018 | 03:44 PM
Best4x4's Avatar
Yep I’m gonna say partially clogged Heater Core as well.
Old Nov 9, 2018 | 06:52 PM
I'm pretty car illiterate. How can I flush the heater core out? Any how to or diagrams?
Old Nov 9, 2018 | 08:01 PM
Best4x4's Avatar
Carefully remove or cut off old 5/8 heater hose from the core, flush with a garden hose. The OEM routing has the lines cross, but the direction in/out of the core is irrelevant so just get new 5/8 heater hose cut it & re-install. Then run it and top off the coolant.
TDRover
Dec 20, 2014 09:53 AM
Savannah Buzz
Mar 13, 2013 02:31 PM
olywa
Jan 13, 2013 05:45 PM
adigerol77
Dec 3, 2011 05:07 PM
DiscoDad
Dec 5, 2010 04:58 PM
