Heater core?
Old Oct 19, 2017 | 05:16 PM
LR03NJ's Avatar
Default Heater core?
A bit cold and I turned the heater on going home and its blowing cold air instead. If its the heater core? and if its clogged, will it over heat? Im near my house when it happened. No further test made yet and its dark out. Thanks
Old Oct 19, 2017 | 05:51 PM
dtmbinb's Avatar
Probably an air pocket. Bleed again then try back flushing the core if the bleed doesn't work. Watch your temps! Good luck!
Old Oct 19, 2017 | 06:04 PM
Friday Night Disco's Avatar
Sounds like what I ran into.
Check my Tricky Dick thread for what I did
https://landroverforums.com/forum/di...hot-air-83856/
Mine never over heated but, it did cause Tricky Dick to run about 10 degrees hotter than what I am running now.
Also note, I did the back flush and while it did get some stuff out, I had to remove the heater core and replace due to amount of garbage in it.
OffroadFrance's Avatar
X1 ........... try backflushing also using a powerful garden hose. Heater matrix are infamous for clogging up with debris and calcium.
DancerDeb
Freelander
Jan 16, 2014 02:39 AM
tgrife
Jul 1, 2007 02:08 PM
97DISCOIDAHO
Sep 6, 2006 04:34 PM
97DISCOIDAHO
Aug 21, 2006 12:49 PM
philipm7
Aug 27, 2005 10:12 PM
