Heater Core / O Rings
Old Oct 19, 2011 | 09:20 PM
sdbimmer's Avatar
3rd Gear
Default Heater Core / O Rings
Ok, Guys, I need some help. I have searched throughout this forum and others about my problem. I have a '99 Disco II w/ 150k miles. Just recently, I have noticed the coolant on the passenger floor and the smell through the vents. All the signs of a bad heater core/ o rings leak.
Here's the problem... The two dealerships I called today to get the o rings both said that on the Disco II's, there are no o rings. The pipes are welded to the heater core. Is this true? And if so, does that mean I need to replace the heater core as well?
I am assuming my o rings are leaking... but if it IS my heater core, I guess that will answer my question.
Somebody please help!!!
Old Oct 19, 2011 | 09:29 PM
The dealer is always the last resort.
Land Rover Parts, Accessories and Information
Old Oct 19, 2011 | 09:30 PM
Here is page from the RAVE tech manual, with dealer "job task number" at the top, they may have a parts list for that job. It says O rings are there.
Since you can get the whole factory manual set for free (this week only) at the link below, you'll save so much money you can afford to get one of those swanking oil drain plug washers you have been wanting as well.
File Type: pdf
Old Oct 20, 2011 | 05:54 AM
tee51397's Avatar
The dealer is incorrect - the lines are absolutely not welded. O-rings & Clamps are used. I believe the part number on the O-rings is STC3166 @ around $11 ea and the size is 17mm ID 18.2mm OD.
Old Oct 21, 2011 | 05:36 PM
sdbimmer's Avatar
3rd Gear
awesome thank you... i'm trying to get those o'rings from the dealer but they're giving me grief.
Just to confirm, this part # will fit a '99 Disco II, right? And, this is the o ring that goes into the heater core, not the other end?
Old Oct 21, 2011 | 06:09 PM
jafir's Avatar
spike555's link listed the part number, and the application:
STC3166
D1 and 2, and the 1995 RRC (has a different dash than the older RRC)
Old Oct 21, 2011 | 06:12 PM
sdbimmer's Avatar
3rd Gear
I'm an idiot...I didn't even see that link!! Thanks again !!!!!
dirtlord
Oct 27, 2014 08:30 PM
Tayrover
Nov 30, 2011 10:37 AM
Spencerfitch
Sep 28, 2010 07:49 AM
JAC
Nov 16, 2009 02:50 PM
wizardmagu
Sep 21, 2008 04:45 AM
