Heater Core O-Rings....maybe
For the past few days I've noticed a small loss of coolant from the reservoir. This morning I found where it was going--my passenger side floorboard. I scanned this site and a couple others and it sounds like my problem may be bad heater core o-rings. I did replace the heater matrix hoses about a month ago because one of them had started to leak.
How difficult is this job to do? I found this how-to guide for a Range Rover (http://www.rangerovers.net/repairdet...html#shortcuts). How similar is this procedure to what needs to be done to an 04 Discovery? Any tips for removing the carpet? I have the RAVE manual, but have no desire to remove the dash (or to pay a mechanic at least $500 to fix two O-Rings).
The fluid is definitely coolant, not water. It is concentrated on the passenger side very close to the door. A little bit seeped back to the rear passenger side as well. I've done what I can to soak up the fluid, but will remove the carpet, shampoo it, and lysol it to prevent it from smelling forever.
The saga continues...
I went out yesterday morning to use some carpet cleaner to make sure I got the last of the coolant out of the carpet. What do you know...it's wet again. I'm taking it back to the shop tomorrow morning so they can fix it again. I've had it back for a week, but I'll give them the benefit of the doubt and see how well they correct their mistake.
wizardmagu
09-21-2008 04:45 AM
