Heavy duty flex plate?
Old Sep 11, 2017 | 01:41 PM
cobbcj7's Avatar
Question Heavy duty flex plate?
I have taken apart my Disco2 again because the transfer case leaked out all of its gear oil and fried... So I am taking it apart and I see leakage from the Bellhousing.. When I did this job last time, I did not change out the rear main or the trans front seal... so now I am doing the job I should have done last time..
My question is, is there a stronger than factory flexplate for my truck? can I double up or make one out of stronger material??
This lightweight aluminum flexplate exploded last time I towed my boat with it. I hate not being able to tow stuff with my truck.
Old Sep 11, 2017 | 03:01 PM
Not that I'm aware of you might check the ashcroft site
Old Sep 11, 2017 | 05:34 PM
Jeff Blake's Avatar
Ashcroft Transmissions
Old Sep 11, 2017 | 05:38 PM
OffroadFrance's Avatar
Originally Posted by Jeff Blake
X1 ........... Ashcroft manufacture an HD flex plate, well worth the investment.
Old Sep 11, 2017 | 05:49 PM
KingKoopa's Avatar
Wow, that's cheap.
So what does the starter engage against in a D2? I assumed it meshed with the flex plate.
Old Sep 11, 2017 | 05:50 PM
Jeff Blake's Avatar
The flywheel
Ya if I knew about this plate when I did the rebuild I would have gotten it. Heck if I knew about it yesterday I would have bought it along with my ashcroft order for 1.41 transfer case gears
Old Sep 11, 2017 | 06:11 PM
KingKoopa's Avatar
The flywheel
Duh, ignore me lol, brain fart.
Old Sep 12, 2017 | 04:54 AM
Originally Posted by KingKoopa
Wow, that's cheap.
C'mon KK, buck up and concentrate harder eh
The flex plate is independent of the flywheel and starter ring gear.
Old Sep 14, 2017 | 08:19 PM
toofaroffroad's Avatar
Atlantic British sells a heavy duty flex plate. I had my blow out last summer and put the HD plate in. It's been great.
Old Sep 17, 2017 | 04:02 AM
There ya go, photo of a flex plate and maybe some answers.
https://landroverforums.com/forum/di...-solved-43687/
Blakesrover
Feb 20, 2013 10:31 PM
calebbo
Nov 9, 2011 11:31 AM
Aj6543
Sep 21, 2009 11:17 AM
Spike555
Jun 2, 2009 11:19 PM
adowgiert
Dec 10, 2007 08:15 PM
