Heavy vibration!!!
Old Nov 11, 2013 | 01:46 PM
jwaters77's Avatar
8th Gear
Default Heavy vibration!!!
New to here, and new to the Disco. I bought my 02 used and never had a problem with it till now. The problem is that there is a very heavy vibration that I can feel through the steering wheel and accelerator pedal once the car shifts from 2nd to third. I have ruled out the tires, as they are brand new and have been balanced and aligned. The disco shifts fine, but am not sure if this is more of a fuel issue or not. Anyone else had this issue? Any insight would be great!
Old Nov 11, 2013 | 01:49 PM
ZGPhoto's Avatar
What speeds are you experiencing it at?
It is not a fuel issue.
Old Nov 11, 2013 | 02:04 PM
jwaters77's Avatar
8th Gear
it starts at around 35 MPH. It is speratic at times, it will only do it once the car has really warmed up.
Old Nov 11, 2013 | 02:08 PM
ZGPhoto's Avatar
Could be panhard rod bushings or drive shaft, but driveshaft usually makes a chirping sound. If it's either of those two things you're going to want to get under there and check it out
Old Nov 11, 2013 | 02:26 PM
jwaters77's Avatar
8th Gear
I looked under there and didn't see any panhard rod bushings that seemed to wore or damaged. I mean if I really get on the accelerator it gets really bad. Any other suggestions.
Old Nov 11, 2013 | 02:46 PM
ZGPhoto's Avatar
Original drive shaft?
Old Nov 11, 2013 | 02:56 PM
jwaters77's Avatar
8th Gear
The underbody looks very good, barely and rust what so ever. The drive shaft is black and looks to be very clean, maybe new not sure.
Old Nov 11, 2013 | 03:02 PM
coors's Avatar
I would look more closely at the panhard rod bushes. Along with all four steering rod ends (the drag link and track rod ends).
Old Nov 11, 2013 | 03:05 PM
ZGPhoto's Avatar
True, it's nearly impossible to tell if your panhard rod bushings are bad by looking.
Old Nov 11, 2013 | 03:51 PM
jwaters77's Avatar
8th Gear
I took a closer look and there is a lot of play just moving back and forth in the drag link which also has the steering damper. Would this be the case?
