HELLA Axillary Lights
Anyone put an axillary lights on the front bumper? Can you post a photo? I am planing on putting HELLA 500 Axillary lights. I want to connect them to the binnacle inside next to the hazard lights switch and to be able to run them independently of the vehicle's ignition. Any step by step will help. Thanks.
RE: HELLA Axillary Lights
It's pretty simple... It comes with a relay...
Starting with the lights open them up, and add a ground, that's the toughest part. I ran that ground to a main ground on the truck. Power from the lights goes to the relay... ground from the lights to any ground, 12v power to the relay, on/off switch to the relay... the switch needs a ground, 12v, then good to go...
97DISCOIDAHO
09-08-2006 11:56 PM
