HELLA Axillary Lights
Old Nov 9, 2006 | 12:36 AM
BuffaloRider's Avatar
4wd High
Default HELLA Axillary Lights
Anyone put an axillary lights on the front bumper? Can you post a photo? I am planing on putting HELLA 500 Axillary lights. I want to connect them to the binnacle inside next to the hazard lights switch and to be able to run them independently of the vehicle's ignition. Any step by step will help. Thanks.
Old Nov 9, 2006 | 10:11 PM
Brad S1's Avatar
Default RE: HELLA Axillary Lights
It's pretty simple... It comes with a relay...
Starting with the lights open them up, and add a ground, that's the toughest part. I ran that ground to a main ground on the truck. Power from the lights goes to the relay... ground from the lights to any ground, 12v power to the relay, on/off switch to the relay... the switch needs a ground, 12v, then good to go...
salve7
Oct 27, 2008 04:28 PM
GoofyMD
Sep 25, 2008 08:20 PM
Chrisinhouston
Jun 24, 2008 04:15 PM
riko suave
Oct 6, 2007 05:52 PM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
