Help!!!
Old Apr 24, 2026 | 05:41 PM
Brat's Avatar
4th Gear
Default Help!!!
New here and have a problem, 2002 disco 2 v8 4l auto. Drove home one night and the next morning it won't start. Cranks over but no starting, no rpm showing on dash when cranking, ( replaced cps and it didn't fix it)
Nanocom can read this fault
2002 discovery 2 fault code p0600 can interface timeout transmisdion control module cycle A determind as persistant signal missing. This is the only fault showing. I did unplug computer behind glovebox to see if any corrosion but it looked good and no water/dampness....plugged back in and "paired" ecu and bcu through nanocom, still cranks over but no start. Both M & S lights flashing, took off xyz switch and looks ok.Dash shows P when in Park, R when moved to reverse, N when moved to nuetral but D flashes on dash, not solid. (this happened only after taking the xyz switch off then re-installing it, so I am sure it needs adjustment now) I did check all fuses and they are good and even swapped out relays. I also don't hear the fuel pump when key is turned to position 2, new fuel pump a month ago but swapped old one back in which powered up before removal and it doesn't now either.
Only have hand tools and Nanocom no electric testing tools and I don't really know what to check next. Please, please help.
ps I am in Costa Rica so parts take months to get.
Old Apr 24, 2026 | 06:48 PM
Extinct's Avatar
Check all your alarm status and inputs using the nanocom. Jumper fuel pump relay and make sure it runs. Sounds like a lockout issue, did battery run down with truck locked?
Old Apr 24, 2026 | 07:47 PM
Brat's Avatar
4th Gear
[QUOTE=Extinct;947237]Check all your alarm status and inputs using the nanocom. Jumper fuel pump relay and make sure it runs. Sounds like a lockout issue, did battery run down with truck ?
The motor turned over fast the next morning no problem. No alarm light on dash. Which slots do I jump on the fuel pump relay?
Brat
Mar 30, 2026 06:40 PM
Kurgan
Jul 10, 2024 06:38 PM
SamPearce101
Apr 25, 2023 02:26 PM
Rich Spiess
Sep 27, 2022 09:32 PM
Squid4life
Dec 22, 2016 10:09 AM
