help
Old May 28, 2008 | 07:54 AM
Sharp1222's Avatar
6th Gear
Default help
I have a 1998 Land Rover Discovery. Saturday I notice that anti-frezze was leaking from behind the right front tire. I could not find the leak. I topped of the fuilds, check my oil, tranmission fuild everything looked good. Truck was not over heating. While driving later I noticed what appeared to be smoke / steam coming from the dash. Then out of the vents, when I turn on the heat, alot of smoke/steam comes pouring out of my vents, like a cloud of smoke, when I turn it to cool air, not so much but still some, and when I turn it off, it appears to come from under the dash. Any idea what is going on hear. Please help
Thanks in advance
Old May 28, 2008 | 07:58 AM
okdiscoguy's Avatar
Default RE: help
Sounds to me like you have a bad heater core. Pop your hood and find the 2 heater hoses going into your dash. Take a small piece of pipe from your local hardware store and join the 2 hoses together.
Make sure and do this with the engine cold! Bleed the coolant system and top off. If it stops leaking, replace the heater core. Good used ones can be found at www.rolerlandparts.com
Old May 28, 2008 | 08:10 AM
Sharp1222's Avatar
6th Gear
Default RE: help
Thanks for the info. One more question, how long can I drive it like this, am i hurting anything else if it had to wait 3-4 days?
Old May 28, 2008 | 08:30 AM
okdiscoguy's Avatar
Default RE: help
I wouldn't wait if it is leaking. These trucks don't take overheating at all. You can drop a liner easy and then your whole engine block is toast. Once you have the parts, bypassing it shouldn't take ten minutes. If you aren't mechanical, call a shop and ask them if they can bypass it. Should do it under $50.
Old May 28, 2008 | 08:43 AM
Default RE: help
Don't go throwing any parts at your truck till you get the coolant system pressurized to confirm what is leaking.
Let us know what you find.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
