help
Old Oct 13, 2008 | 07:01 PM
asamac's Avatar
Default help
i need help. keys stuck in ignition and also can engage gears with out pushing button on auto shifter in 98 disco 1. any info that can help me fix this would be greatly appreciated.
Old Oct 13, 2008 | 07:46 PM
Default RE: help
I am going to guess that you are not all the way in park.
The transmission shift linkage will stretch over time and eventhough the selector says park you are not acutally in park.
Take a small thin blade flathead screw driver and pop the trim piece off the top of the shifter ****, tighten the bolt ontop of the shifter and then run it through the gears and see if that helps.
Old Oct 13, 2008 | 08:41 PM
asamac's Avatar
Default RE: help
will do thanks alot
Old Oct 14, 2008 | 09:09 AM
Default RE: help
If that doesn't work, you will most likely have an issue with the lock assembly in your steering assembly.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
