help
Old Aug 24, 2009 | 02:15 PM
june_chris's Avatar
4wd High
Question help
okay so we are having issues with our 99 discovery II, many said it was the ignation coil, but ordered 1 from roverland replaced it and thats not the issue!! so this is what happens, it starts and drive untill i turn it off then it will not restart for atleast in hour, it wants too, but just will not fire..... the lights and everything turn on!!! we are on a limited buget so need help with and ideas!!!
Old Aug 24, 2009 | 02:18 PM
Any fault codes??
That is pretty common with our Disco's near 100,000 miles, the crank sensor starts failing and shuts of the fuel and or spark.
Old Aug 24, 2009 | 02:45 PM
june_chris's Avatar
4wd High
Originally Posted by Disco Mike
Any fault codes??
yeah i took it to autozonebecause its free and the only thing it shows is the o2 sensor!!!
Old Aug 24, 2009 | 02:46 PM
june_chris's Avatar
4wd High
any clue on where or how much the crank sensor is!!?? mine has 134 on it!!
Old Aug 24, 2009 | 02:50 PM
AK Rover's Avatar
Crank sensor is down on driver side rear of the engine. It reads off tabs on the flex plate to get the crank position.
Old Aug 24, 2009 | 03:00 PM
june_chris's Avatar
4wd High
thanks, wouldnt that showup on fault codes!!???
Old Aug 24, 2009 | 03:02 PM
june_chris's Avatar
4wd High
is this what it is!!!?? Duralast / Crankshaft Position Sensor
Part Number:
SU5570
Price:
$59.99
Warranty:
2 YR
Old Aug 24, 2009 | 03:38 PM
lipadj46's Avatar
yes that is it.
Old Aug 24, 2009 | 07:34 PM
june_chris's Avatar
4wd High
thanks all of you!!! ijust ordered one, hopefully it works!!LOL
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
