Help 4 hrs from home need tensioner pulley help!
Old 08-27-2013, 10:22 AM
94svt50's Avatar
Thanks Buzz for all the help those reference numbers saved the day! I replaced the whole assembly with the dayco 89287. Its not as robust as the oem unit but I will take what I can get. The grinding rattle is gone, glad this thing didnt fail down I-75 somewhere. So, anyone think with the two idler pulleys failing and grinding that could have caused a low voltage situation throwing the 1562 code? Im going to check all the connections I can find right now.I have driven about 20 miles since code cleared on its own and it has not come back yet. thanks again.
Old 08-27-2013, 10:41 AM
drowssap's Avatar
hell five kids, plenty of pushing power
Old 08-27-2013, 10:56 AM
94svt50's Avatar
Maybe that would tire them out enough that they would actually take a nap.
Old 08-27-2013, 12:00 PM
If you are still having issues, get your charging system voltage tested under full load. The voltage has to be between 13.6 and 14.4 volts.
And, as for that code, I have checked all six of my Rover fault codes and yours is not one of them.
Old 08-27-2013, 02:43 PM
94svt50's Avatar
The ultra gauge said it was a p1562. I have driven 50 miles and is not come back.
Old 08-27-2013, 03:17 PM
That is not the first time an ultra gauge has thrown a non Rover code.
Sea Paddler
08-27-2012 02:32 PM
jycsalas
04-01-2009 07:43 AM
souljad9
11-19-2008 11:50 AM
andrewmcoffin
03-10-2008 08:52 AM
ajh
12-19-2007 11:30 AM
Quick Reply: Help 4 hrs from home need tensioner pulley help!
