HELP! '98 Disco won't start
Old Apr 18, 2009 | 11:26 AM
Ursulann's Avatar
6th Gear
Default HELP! '98 Disco won't start
I have a 98 Disco I with 80k miles & it's been giving me major problems for the past few months.
The problem: it won't start. It sounds like it will almost turn over, but then dies. No codes.
Replaced the Crank Shaft Sensor, it ran fine for about 3 days -- then it slowly died while driving again w/the same symptoms. Then replaced the Fuel Pump (just the pump - used the old housing). After that it ran for 12 hours, then died again.
Recently Replaced:
Fuel Relay Switch
Inertia Switch
Fuel Filter
Plugs & Wires
Battery
Any trouble-shooting suggestions would be greatly appreciated. Love my Disco & would like to get her running again without spending another fortune at a mechanic.
Thanks!!
Old Apr 18, 2009 | 11:54 AM
jimbo97's Avatar
Turn the key on and listen for a hum in the cargo area. If no hum, pop the hood and look for a silver tube on the passenger side. There will be what looks like a valve stem for a tire. Take the cap off and push in the valve as if you are letting the air out of a tire. Be careful, as this should relieve fuel pressure. If fuel does not squirt out, I would start with the fuel filter, then move on to the pump. It can be accessed under the carpet in the cargo area.
Old Apr 18, 2009 | 12:00 PM
jeffrudy's Avatar
it died while driving???!!! or just wont start? i had similar problem with one of my old discos it was a '95 might be the same though i just cranked and cranked but wouldnt start up. i replaced all kinds of stuff trying to fix it but it seemed nothing would work if i had to do it all again id go this route
replace your lucas ignition moduale with one from http://www.toddcosuspensions.com/discovery.html
look at replacing you distributor bits too.
Old Apr 18, 2009 | 12:05 PM
jimbo97's Avatar
Smile check out my thread
or you can check out my thread that i post it so you can see some of the info that what might wrong with you truck , because i had the same problem but still you can ask some of the guys . they will help you figure it out what's the problem
Old Apr 18, 2009 | 02:23 PM
Ursulann's Avatar
6th Gear
Yes, initially it died while driving. Now it just won't start.
Could the check engine light just not work? Should I try to see if there are codes even though the light isn't lit?
Old Apr 18, 2009 | 03:09 PM
AK Rover's Avatar
When you turn the key on does your check engine light come on? It should come on while it tests the circuits then go off if there are no codes. If you have a code reader plug it in and verify there are no codes.
Did it run at all after you replaced the battery? I'm thinking the alternator is your problem. It's not charging the battery and what little power you're getting is strictly from the battery. That's the only reason I could think of for what you're describing. Take your alternator to an auto parts place and have it tested.
Your 98 uses a distributorless ignition system so the parts jeffrudy linked to will do no good for your Disco.
Old Apr 18, 2009 | 03:29 PM
Ursulann's Avatar
6th Gear
Thanks AK Rover!
Yes, when I turn the ignition on, the service engine light does come on -- then goes off like normal.
Yes, it did run after the battery was replaced. But through all of the current repair and then trying to start the engine, the battery quickly drains. I will try having the alternator tested next.
Old Apr 18, 2009 | 03:58 PM
I vote a bad alternator.
Old Apr 19, 2009 | 01:57 AM
jeffrudy's Avatar
eh yea forgot i have an old disco and the newer dI's have distributorless ignitions... ive only owned '95's : )
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
