Help! Anyone know what his is and where to buy it. From 2000 Discovery 2
Old Dec 10, 2022 | 02:20 PM
landroverken's Avatar
4th Gear
Default Help! Anyone know what his is and where to buy it. From 2000 Discovery 2
Hello. At the back of the engine block where the main harness bolts to the back of the head, there are the 2 green ground wires. Inside the harness all taped up are what looks like a capacitor. There is one on each ground wire. Does anyone know where I can buy this? Not sure what to call it. I've googled it but no luck. You usually don't see this because it's normally all taped up in the engine harness. The green ground wire is soldered to this piece (capacitor) and I can't seem to get it soldered back. Won't stick. Both of these are separated from the ground wires. The capacitor looking thing (technical term) is covered in a red plastic coating and underneath that it's blue.
Old Dec 10, 2022 | 04:39 PM
4th Gear
Still not for sure what this is but I think it might simply be a noise suppressor since there are 2 of these. Each connected to the positive wire going to the coil and the other end grounded. If that's the case, then it won't matter if I leave them off. Hope so because I am replacing the head gasket and I'm about to put it all back together without these connected.
Old Dec 10, 2022 | 05:14 PM
Harvlr's Avatar
Sorry I don’t remember such wires when I did my HG’s.
Old Dec 10, 2022 | 06:51 PM
4th Gear
You probably would never see it. All you normally see is the green ground wire sticking out of the main harness. One green wire on each side running up to each ignition coil. I only saw it because the bolt stripped that holds the main engine harness to the back of the heads and I had to pry it out when a screw driver which exposed it from the wire loom. Anyway, pretty sure it's just a noise suppressor they added from the factory to keep ignition noise from being picked up by the radio. Guess I'll find out for sure when I get it back together. lol
Alex_M
Sep 29, 2022 11:56 AM
WarrenZ
Feb 17, 2022 08:54 PM
merlinj79
LR2
Jun 21, 2021 08:54 AM
Kentral Gross
Jan 9, 2020 10:04 AM
03discoman
Audio/Visual Electronics
Dec 24, 2009 09:16 AM
